'59 F100 radiator support
Old 09-16-2015, 12:18 PM
SeaCarr's Avatar
SeaCarr
SeaCarr is offline
Anyone have luck repairing the lower middle bar of the radiator support? I have lots of corrosion and was wondering if it was worth trying to make a weld repair.
Old 09-17-2015, 04:01 PM
stevevize's Avatar
stevevize
stevevize is offline
1959 Radiator support
I repaired the right side of my 59 with a piece of 1-1/2" angle thus eliminating the 3 sided channel. It was easy because it was a straight piece about 10" long. In the center area I would cut out the bad stuff then using 1-1/4" angle (the dimension is different as you will notice) fab a new piece making careful cuts on the proper angles on both sides to make "a smile" looking support. Weld in place and you're good. That metal is thick enough to weld to using a wire feed welder. I don't know how bad yours is but you shouldn't have to be concerned about bolt holes like I was. When the front clip is all put back together, only a purist will ever notice your work. If you are a purist, disregard above. lol. Good luck.
Old 09-17-2015, 09:10 PM
SeaCarr's Avatar
SeaCarr
SeaCarr is offline
Thank you for your reply. I was flirting with some ideas like that but not having welding experience I wasn't sure I was on the right track. Mine is corroded at the bottom. The tracks the radiator fits into seem to be ok. They are next on the de-rust task when I figure how to get into it. Way I see it is if I can't buy one, I'll have to follow your lead.
Old 09-18-2015, 11:15 AM
stevevize's Avatar
stevevize
59 radiator support
From what I have gathered this is a common problem and sorry to say but it would be a miracle if you found one. I have seen some for different years. Try Ebay; they are full of surprises.
Old 09-22-2015, 11:22 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
C0TB-16138-C (replaced B7C-16138-A) .. Radiator Support / Obsolete ~ 1957/60 F100/600.
No Ford dealer or obsolete parts vendor has any.
Ki-Adi-Mundi
15
05-08-2017 05:32 PM
ohbrian
17
10-15-2013 12:52 PM
Bozworth
10-05-2011 11:58 AM
sharpster68
05-23-2006 08:16 PM
MRZ
12-08-2003 11:53 PM
Quick Reply: '59 F100 radiator support
