Not the one at LMC, page 145. Mine has two very strong L shaped brackets that bolt to the firewall. The tray is rotted out. I don't think another mounting would hold the heavy battery. I just saw a 59 restoration with the same bracket as mine but I have not been able to find one online.
I think the LMC battery tray replacements with one support bolt to the other original support on the other side with bolts, nuts, washers shown as part# 7,8,9 in the illustration. If your original support is still usable it should work.
1957/58 F100/600 battery tray is not the same as 1959/60 (COTB-10732-A), and there are two different sizes. One for the 55 amp battery (B7C-10732-C), another for the 70 amp battery (B7C-10732-D).
i knew the 57-58 was different than the 59-60 i was going to send a pic to him with the 3 that i have, he mentioned 59 battery tray, Bill you mentioned the 70 amp battery tray was different, you know i need to send you a pic of 2 that came from preston, in fact these all came from pres, i am not sure what the 2 fit maybe thats what they are for the larger battery.?
The 59 parts truck I had was different than the tray in my '60. I was able to combine the two trays and end up with a decent set up though, using the mounts off the '60 and the pan off the '59. Just a heads up that '60's are different from '59 in some cases.
