7.3 going to idle mode
Old 09-15-2015, 03:41 PM
csj992's Avatar
csj992
csj992 is offline
Hey guys, started working on my 96 f250 powerstroke again. The truck will be running and lose power, going into idle mode and will stay there until I release the accelerator and then go on. I was told that the PCM is doing a restart from losing power momentarily. It has had 3 pcm's same problem. Any thoughts would be appreciated. I have tried just about everything and cannot get it fixed.
Old 09-15-2015, 03:51 PM
lee00's Avatar
lee00
lee00 is offline
My guess would be the pedal position sensor... for give me as I don't know the exact term.
But it could be a lot of other things too... best would be get a scanner on it and see what you get for sensor feed back
Old 09-15-2015, 07:00 PM
csj992's Avatar
csj992
csj992 is offline
Hey lee00, I was thinking if it were the TPS that a code would be thrown. When it fails all I get is the WTS light flashes and it is in idle mode. I have been told the only thing that causes the WTS to light would be a power failure. Thanks, I might just try a new TPS.
Old 09-15-2015, 07:08 PM
fordpride's Avatar
fordpride
fordpride is offline
Is the truck chipped ?
If the wts is coming on then the pcm is losing power.
Old 09-15-2015, 07:12 PM
97-psd's Avatar
97-psd
97-psd is offline
Sounds more like an IVS. For a lack of better words, it can make the TPS signal drop out making the truck drop to idle. I can't remember off the top of my head how to check it but search IVS and there are a couple of threads that are really helpful
Old 09-15-2015, 07:21 PM
Action4478's Avatar
Action4478
Action4478 is offline
Sounds like the IVS to me too other than the WTS light coming on .
Old 09-15-2015, 07:50 PM
fordpride's Avatar
fordpride
If the pcm loses power then Ivs will have to be repressed.
If you take the Ivs off and let it hang you can just click it and drive all day but after yiu shut of the power then it'll have to be clicked again.
Old 09-15-2015, 08:01 PM
Action4478's Avatar
Action4478
Why would it need to be re pressed ? If its closed , its closed
Assuming it is working properly to begin with . PCM needs to see a closed IVS always .
Old 09-15-2015, 08:26 PM
Action4478's Avatar
Action4478
I did a little test after reading your post . Started the truck with the go pedal matted . Shut the truck off & started it again . the IVS needed to be reset . You were right .Sorry .
Old 09-16-2015, 06:46 AM
fordpride's Avatar
fordpride
Nice go see you around Rick
How have you been ?
Old 09-16-2015, 09:25 AM
csj992's Avatar
csj992
csj992 is offline
Really appreciate all the replies. The truck is not chipped. I can duplicate the trouble with the ivs but I don't get the wts light. I have monitored the voltage in to the pcm with no loss of voltage when fault occurs, which tells me I could be losing ground. I was wondering if there is any condition that would light the wts other than lose of vpwr. Sure wish I could have a common fault that would set a code.
Old 09-16-2015, 10:05 AM
fordpride's Avatar
fordpride
Are you 100% sure it's not chipped?
Possible causes
Lose chip
Bad wire to pcm
Bad connection at pcm
Lose/bad wire at ignition
Ignition out of adjustment
I'd start the truck and start shaking wires at the pcm then open up the steering column and start tapping wiggling the ignition and rod
Old 09-16-2015, 11:36 AM
csj992's Avatar
csj992
csj992 is offline
Yea Mike. I am the second owner of this truck. Plus it is on it's 3rd pcm so no chip. I replaced the ignition switch(one with contacts), but I was wondering if the rod going down the steering column could somehow get out of adjustment or if the tumbler part of switch is not pushing the rod completely. This has been a bugger.
Old 09-16-2015, 01:34 PM
madpogue's Avatar
madpogue
madpogue is offline
If the WTS light does not come on when this happens, the IVS is the prime suspect. Power to the IVS is via another fused circuit. Don't remember which circuit offhand; EVTM is out in the truck and it's pouring rain.
Old 09-16-2015, 02:00 PM
fordpride's Avatar
fordpride
Post 3 states the WTS is coming on.
Quick Reply: 7.3 going to idle mode
