Plastic Inner Fenders (Removal)
No need to remove the fenders. There will be several screws that attach to the fender well. Some through the sheet metal and some with u speed nuts. There will also be two near the front bumper (probably 8mm) nut. There is also one by the rear of the tire that connects to a metal tab near the exhaust. The D/S will require the removal of wire holders and any other components may need to be detached from wires you may have. The P/S will probably need some vacuum lines removed and possibly other items attached to the wall. Oh ya, there will be a screw and a bolt under the fender near the door. Now, depending on where you live, these items may be rusted and hard to remove. Sometimes a grinder, strong snips, and a little luck.
1.) Pull the tire, 2.) Clean the inner fender 3.) drape the undercarriage with a tarp, 4.) Tape / mask the outer fender, and 5.) Spray paint
g-money-55
06-10-2019 09:04 PM
epos48
12-09-2004 10:53 AM
CheeseandRice
05-28-2003 11:12 PM
