Steering columns the same for all 80-86 trucks?
Looking to change my 81 F150's column back to an automatic column. Someone swapped in a manual column when they installed the ratchet shifter on the floor and I would personally like to go back to the column shifter.
My question is, are all 80-86 automatic columns the same? I would need one with no cruise control wiring.
<p>I think it was 1984 when Ford started with the buzzer when the key is in the ignition and the driver's door opens; whether or not the pre-1984 columns can accommodate that circuitry (part of the turn signal switch) or not is something I don't know. But it won't hurt a 1981 truck that doesn't have the wiring for the buzzer but has a column that can accommodate it....</p><p>Cruise control wiring... IIRC the columns are exactly the same in that regard and it's just the wiring that gets added in when cruise is installed.</p><p>Tilt vs. non-tilt, automatic or manual transmission, those are the differences...</p>
So, what did a previous owner do, replace the A/T's shift collar with the steering column extension from the 4 speed...in order to get rid the empty shift collar hole, now that the shift lever is on the floor?
Sorry I didn't reply sooner, I was at work. The truck was originally a 300/C6 truck. When they swapped in the 302, they attached it to the original C6 and removed the automatic column and put in a manual one and put the ratchet shifter on the floor. The current column has a collar cover and a key release button.
The truck is a F150 Custom, so I assume it didn't come with cruise control as I do not see anything that would indicate it under the dashboard.
kitkar
04-23-2018 03:58 PM
mrwildcat2u
03-04-2012 01:37 AM
Garandag
09-18-2005 10:55 PM
