Bendix Adjustment?
Bendix Adjustment?
Is there one. I would like to avoid grinding the teeth off like the last one. Are there any adjustments or clearances? I failed to take any notes before removing the last one though it had ground teeth so may not have been right. From the looks of it you just push it on all the way and set the screw but I feel like there should be a feeler gap between the gear assemble and the starter body?
kindashort
07-10-2010 12:10 PM
