Windshield washer fuse location?
Thanks for the link.
I guess I was not as clear as I thought. I need the fuse location for the sprayers. My wipers work but I can not get fluid out front or rear. I can not even hear it turn on so I am thinking it is a fuse.
I read that the motors go bad, but I rather try the easy stuff before I dig into replacing pumps and spray lines.
Chris
Chris
had to edit, had pulled up the Expy EVTM by accident, Missed it by "thismuch". Corrected as of 7:15 AM CDT.
Does the rear washer and wiper work? The front and rear circuits are inter-mixed. There's only a single pump motor for both front and rear located under the hood, behind/under the right headlight.
The following fuses are potential suspects that you can check: CJB - F106, F33, F48, F21. Those are the fuses that are at all involved with the washers/wipers, both front and rear. I did not parse the list for exclusions.
Last edited by projectSHO89; 09-15-2015 at 07:15 AM. Reason: Corrected for Excursion...
accent2010
Escape & Escape Hybrid
03-20-2017 01:57 AM
