99 expy tranny issue
Ok so I have a 99 expy 5.4l with roughly 180k on the tranny and body. My wife's od light on the shifter started flashing bout 2-3 weeks ago. It doesnt do it all the time tho. I searched around a bit and decided to change the fluid and filter with nothing changed when I did. Fluid looked pretty clean normal wear and tear fragments on the magnet. Finally had a code p0708. It said trans position sensor. Changed that out and still have the od light flashing. I have no clue at this point. Its not slipping it'll only bang a but upshifting. Any help please
Your awesome. Thank you so much I really appreciate the help. I'll be chasing wire tomorrow in a tight spot with Hugh hands lol. Again thank you. By any chance do you know if I would fail emissions for the tranny code? Its not part of the emissions system. Can't find any laws on it for ct.
Ok I've tested a few things with my volt meter but how would I go about this? This is starting to walk the line of not that I don't know what I'm doing but more of the damn i hate freaking thing. But any and all help is awesome. Oo my wife noticed last night that when the tranny light flashes and it acts up, it sounds like a whinning noise is coming from the tranny.
Unplug the VSS and unplug the harness at the computer.
Get a jumper wire so you can test from the computer connector to the VSS connector.
NEVER put a probe into the end of the connector that makes the connection. That will open the pins and they won't make a good connection. It creates problems where there were not problems before. Always probe the back side of the connectors.
Check each of the wires to the VSS for continuity, for a short to a power wire, and a short to ground. Also look at the connectors and see if there is any corrosion on the pins.
The tech himself said it shouldn't fail for anything that has to do with the tranny but ct doesn't care. When I pulled it in the bay it was off, so either the obd computer forced it on or it came on by itself. Which I've never had it come on with the tranny problem if its sitting at idle. So they gave me 60 days to fix it and I don't have to pay for the retest. A buddy of mine said to change the speed sensor, could that cause this?
