Choking out
Choking out
I have a 1999 Ford F-150 with 149,000 miles on it and when the engine gets warm it seems to flood its self out. I was told to change fuel filter, no change, I was told maybe the catalytic converters maybe plugged but then was told that wasn't the case either. Another mechanic mentioned some sort of ignition relay or computer issue? I do not have any lights on of any sort. I do want to mention before it started acting up the auto door locks would jump up and down erratically and my key phoebe will not work now. Any help would be greatly appreciated, thanks!
You may have 2 issues.
You have not given enough about the drivability issue.
Flooding out is not enough.
If there is no CEL light, then a Scanner is needed to look at the live data for a clue.
Otherwise it is just guessing like the advice you already got.
Tell us how it starts, idles, runs specifically.
Good luck.
Good luck.
Starts normally, idles fine, a little slow when cold, drives good for about 20 mins at 55 to 60 miles per hour, then it acts like it ran out of gas. I have a guy hooking up a scanner today hoping it will reveal some kind of code. Thank you for your response and if you have any idea they are more than welcome!
lvin4jc
03-25-2013 07:03 AM
yeomansjon
05-21-2012 09:55 AM
