Anybody using these headers? - Ford Truck Enthusiasts Forums
Old 09-13-2015, 11:54 PM
harleymsn's Avatar
harleymsn harleymsn is online now
harleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to all
Ilya pointed these out to me recently. I have a cracked manifold on the 51 that looks pretty bad. When I saw these and the price I started wondering if anybody has any experience with them. One thing I would like to know is how close to the frame they get as I am concerned about clearance for the steering column going to the Jag IFS.
https://www.bobdrake.com/FordItem.as...5-5a064ee2cbcf
Old 09-14-2015, 06:17 AM
49willard 49willard is offline
49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.
Joe,
Having been thru the process of installing the Jag I would not buy any manifolds until I had the Jag installed and you are mocking up the steering column/ujoints and shafts. Mine is a SBC and no aftermarket manifolds worked. That said I think that the flathead V8 will bring the manifold/headers in closer to the centerline of the chassis than for the SBC.
Old 09-14-2015, 12:08 PM
harleymsn's Avatar
Quote:
Originally Posted by 49willard View Post
Joe,
I don't plan to buy anything just yet, doing a little research. I thought the same thing you did about being closer to the centerline, but just wondered if anyone out there had installed a set of these.
Old 09-14-2015, 01:10 PM
JPMallory's Avatar
JPMallory JPMallory is online now
JPMallory has a very good reputation on FTE.JPMallory has a very good reputation on FTE.JPMallory has a very good reputation on FTE.
I was just looking at those earlier this morning. Im on the fence about buying them.
Old 09-14-2015, 02:46 PM
JPMallory's Avatar
Ok. Im no longer on the fence. I ordered them. Ill post an update when I get them installed.
Old 10-03-2015, 09:48 AM
JPMallory's Avatar
Ok, the headers are installed.
Old 10-03-2015, 12:20 PM
harleymsn's Avatar
Those look pretty good, especially for the price. It also appears to be a very clean install.
Old 10-03-2015, 01:02 PM
JPMallory's Avatar
Other than some difficulty with a starter cable that didn't want to get out of the way. Other than that, it went pretty smooth.
Here's a crappy video I took right after I installed it.
Now I just need to get it to shop to have the exhaust run.
Dislexic Shifting? jmadsen 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 01-27-2017 06:21 PM
LED's in Cluster and HVAC Wheelman55 1987 - 1996 F150 & Larger F-Series Trucks 8 08-16-2016 08:03 PM
My 69 build so far Ikestang 1967 - 1972 F-100 & Larger F-Series Trucks 8 08-11-2016 06:20 PM
Codys 04 f250 build thread Codyaye 1999 to 2016 Super Duty 55 06-03-2016 12:29 PM
How To: 65-66 parking brake assembly TA455HO 1961 - 1966 F-100 & Larger F-Series Trucks 26 12-01-2015 03:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
