weird problem changing sparkplugs
03 f150 5.4.. on the firewall passenger side i cannot get a socket on it. Changed out the others on that side no problem...for some reason socket wont fit. Im using a 5/8. I cant see into the hole...blew it out with air for kicks. Nothing. I know i need to get a mirror but just Wanted to check and see if for some reason anything is different.
Edit..i did not remove fuel rail as it wasnt needed for the previous 3...angle still seemed same assumed it was.
