Project Charlee the powerstroke
#226
It's really not that bad at all!! The majority of my waiting was not having enough muscle or hoist to move around the engine. I probably took a day to tear everything down, a few hours to pull/reinstall engines, and a day to reconnect everything and fill with fluids..... over a 2 month period lol
#227
Ok... Took the truck for its first drive yesterday. The trans isn't shifting!!! It's stuck in second until I put it in manual 1st, and if I do that and shift to manual 2nd, it won't shift until I put it in drive! After that, always in second.
My computer power source us at my parent's house so I can't check with ae. I must have missed a ground somewhere??? That's the only thing I can think of. I'll pull the chip tonight to see if that does anything.
#228
#229
#230
Ok guys, I just drove my truck in to work with no hiccups!! I have a CEL for a bad EBP sensor, which is weird because it wasn't doing that before the motor swap. I am thinking I didn't plug the sensor in all the way. She shifts and acts just like a stock, non chipped motor... so SLOW!! I can't wait to get the dough to pay Jim to redo my Stage 1s. Until then, I guess I am glad I had a good set of stock sticks for the meantime.
#231
#234
It should read around 14 PSI atmosphere
With some more RPMs and or boost, the turbo will create back pressure and it will go up in reading
#236
So I made a big step toward my RSK/lift step of the rehab of Charlee. This will be the last major component I am needing to rebuild to basically have a new truck (already rebuilt/replaced the motor, trans and rear end)
Here is how she sits as of Tuesday:
And the VIN from the truck I pulled the axle out of...
Here is the axle as it sits now in my front yard (aka parts depository)
So now i am looking for a rebuild kit for the front end. I have a very strong feeling I will be needing to regear the axle also (I would probably change the r&p anyway for peace of mind). Anyone have a suggestion for an overhaul kit? I am seeing one from Yukon through some online store:
Yukon Master Overhaul kit for '98 & down Dana 60 and 61 front disconnect differential. - RuffStuff Specialties
I would get the R&P from Yukon also unless I can find a steal of a deal somewhere else.
I can't wait to not have slop in my mother loving steering and no more pull!!! woot woot!!
#237
Confirmed, it has 4.10 gears in it.
https://www.summitracing.com/parts/m...-354/overview/
http://www.ruffstuffspecialties.com/...PP-CK-D60.html
#239
