04 5.4L SCREW Erratic Speedometer
Mine does not come on and off when banging on it like yours did. I assume these do not have a cable. I wonder if it can be a fuse just for the speedometer and maybe the fuse is intermittent and not just burned out? LoL
Here is a link.
https://www.ford-trucks.com/forums/1...r-windows.html
The speedometer is completely internally controlled by the instrument cluster based on a CAN Bus data signal from the PCM. If the the speedometer is the only problem you are having with the IC, it would sound to me like a problem inside the IC (connection between the IC's microprocessor and the speedometer's stepper motor, solder joints have been issues on other Ford IC's), as I believe a CAN communication issue would cause the MIL (Malfunction Indicator Lamp/Check Engine Light) to illuminate.
So you are saying that this has no Speed Sensor anywhere which provides that signal to the PCM?
If not, what is this?
https://amzn.to/2wqpNYh
yes, the sensor reports the vehicle speed to the PCM, but, if the signal to the PCM was erratic, I would expect to see drive ability concerns and/or a P0500 code. cracked solder joints in the IC are way more common, but if you want to know for sure if the VSS signal is good, you can use a scan tool to monitor the VSS PID while the speedometer is acting up.
justin_tractors
Modular V8 (4.6L, 5.4L)
12-25-2005 01:01 AM
