Disaster has struck (F-350 6.0L)
Here is a direct link to the map >> https://www.google.com/maps/d/edit?m...Q.knVowsrkSusg
But you can find the map thread here >> https://www.ford-trucks.com/forums/1...forum-map.html
Tom the set PSI for that useless gauge is 7 PSI.
Sean
6.0L Tech Folder
Sean
6.0L Tech Folder
Just to add a little more detail on the oil pressure:
The oil pressure switch activates at 5 psig.
The oil pressure switch engages at 5-7 psi to move the dash indicator to the mid zone.
Anything less than that will just show no oil pressure.
12 psi at 700 rpm is minimum recommended (24 psi at 1200 rpm and 45 psi at 1800).
I have thought about a small intake side leak as that would be the only way for two gallons of oil to disappear in just a few thousand miles without residue or oil stain somewhere including the exhaust pipe. I will watch it close and I will check before I start it this morning.
Which brings up the fact that hot there is no oil on the stick and cold it shows at the top of the full mark.
No, because there's not a true low oil pressure sender.
With this motor, if the low pressure pump isn't pumping the motor won't run because the high pressure pump (that also gets it's oil from that pump and supplies oil to fire the injectors) won't have any oil to fire the injectors.
Per the oil change procedure in the Tech section "Oil can stay in the upper portions of the engine for up to 20 minutes after the engine is shutdown."
Maybe wait 20-min and then check?
It's also possible that you may have some strange electrical "things" going on due to poor grounds, poor connections, and/or RF! (if you're generating a LOT of RF)
When I had a much older F-250, and when running 600w on 75 and 40, it did all sorts of things to the gages and other electrical "stuff' in the truck. (luckily I had mechanical injection and a manual trans)
I can only surmise what would happen to the ECM and FICM, transmission control, and other "things" in the presence of high power RF either in a near field or in the electrical system.............
73/Rick
It would add some delay to the gauge. Ever watch it
after an oil change? Not all that instant is it.
Sean
6.0L Tech Folder
Sean
6.0L Tech Folder
It always takes my gauge "a bit" before it comes up after the motor starts. And I can hear the turbo vanes move at the same time.
#28
#29
