1978 - 1996 Big Bronco
re-gearing
Old 09-09-2015, 12:23 PM
peeples93's Avatar
peeples93
peeples93 is offline
re-gearing
I have a 91 bronco pushing 35s and I wanted to get some advice on regearing it for some more power
Old 09-09-2015, 12:29 PM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
most will tell you 4.56, myself I went with 4.88's to have a little extra rpm's and love the setup both onroad and off.
what motor/trans do you have.
Old 09-09-2015, 12:54 PM
peeples93's Avatar
peeples93
I have a 5.8/351 windsor and an automatic e40d
Old 09-09-2015, 01:04 PM
peeples93's Avatar
peeples93
Old 09-09-2015, 09:01 PM
Black Ford XLT's Avatar
Black Ford XLT
Black Ford XLT is offline
4.88 best bet I agree
Old 09-11-2015, 10:09 AM
AbandonedBronco's Avatar
AbandonedBronco
AbandonedBronco is offline
Engine RPM = (Speed * Transmission Gear Ratio * Final Drive * 336) / Tire Diameter
The E4OD's gears are:
1st: 2.71
2nd: 1.54
3rd: 1.00
OD: 0.71
Use that to find out what RPMs your engine will be at for a given speed and see which gearing you'd be most comfortable with.
For example, if you want to go 65 in overdrive:
4.88
RPM = (65 * 0.71 * 4.88 * 336) / 35
RPM = 2160
4.56
RPM = (65 * .71 * 4.56 * 336) / 35
RPM = 2020
etc.
Play around with it for 1st / 2nd gear getting up to speed. Going 35 in town, etc.
If you're looking for more power, remember that, simply, the more aggressive your gearing, the more power you'll have. So there are more factors than just "more power". Some 5.14s, or even 5.71s are going to net you even more power yet.
You need to decide what you want to do with the vehicle, where you want the power, and where you want to draw the line. Is it a rock crawler? Do you want to use it on the freeway? Etc.
austynn2001
01-03-2005 10:29 PM
Dougie
02-09-2004 08:55 PM
JCastellaw
01-14-2004 11:03 AM
lt
09-04-2001 12:00 PM
Quick Reply: re-gearing
