hey there i have a '93 f150 with a mazda m5r2 tranny. i need to bleed the slave cylinder but it is concentric (inside the transmission) and i am trying to avoid taking the transmission out any help is appreciated.
The bleeder is above where the line goes into the transmission if you're by yourself bleeding it by opening the screw and letting it drain through works just fine
11mm bleeder screw
so i bled it and it worked, then i tried it again later and it is doing it again. i think the slave cylinder is getting air inside of it somehow. now i need to tak ethe tranny out and change the slave, and while i have it out ill change the clutch, pressure plate, and throw out bearing.
