95 F150 4X4 5.0 Gear Ratio Change - Ford Truck Enthusiasts Forums
Old 02-25-2002, 08:08 PM
EWE EWE is offline
EWE is starting off with a positive reputation.
My '95 F150 4X4 5.0 AOD is an absolute stone! I made the mistake of ordering it with the 5.0 and stock gear ratio (3.37:1 I think). It downshifts out of overdrive constantly when I encounter the slightest grade. The gas mileage is hideous! hideous!!! No matter how I drive it.
I've been considering a switch to 3.91:1's, a catback exhaust and a K&N filter element.If I'm going to live with 10-12 MPG (the sticker said 14-19), I might as well have a little throttle response.
Anyone have any experience with this combo? How do I correct the speedo and odometer after the gear change(s)? Any good manuals available for installing the gears and setting up the pattern and backlash?
Old 02-26-2002, 01:13 AM
Ryan50hrl's Avatar
Ryan50hrl Ryan50hrl is offline
Ryan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to behold
You probably have the 3:31 gear ratio, and your tranny is more than likely a slightly improved AOD with a wider gear ratio named the 4r70W. I'm encountering the same problem with my truck, only its amplified by the fact that i'm turning 35's. I would say that a 4:10 Ratio should do pretty well for us. Good luck and let me know what you decide to do.
Ryan
Old 02-26-2002, 01:15 AM
Ryan50hrl's Avatar
oh..and by the way....the speedometer will automaticly correct for the gear swap, a tire size it will not correct for. Summit Racing has a good video on gear set up available. I belive Richmond gear produced it.
Old 02-26-2002, 01:49 AM
HippieCustoms's Avatar
HippieCustoms HippieCustoms is offline
HippieCustoms is starting off with a positive reputation.
What size tires are you running? I loved the gear swap I did to 4.56 when I was running 36 " tall tsl's. Since I went to the 39.5's, I probably should change to 5.14. I also still get 11 to 12 mpg depending on how I drive. good luck.
Old 02-26-2002, 03:13 PM
fiveptO fiveptO is offline
fiveptO is starting off with a positive reputation.
Try this link out. I used it to change the gears on my mustang... http://www.corral.net/tech/ click on tech articles and then on 8.8 gear install.
scott
Old 02-26-2002, 06:56 PM
EWE EWE is offline
I'm running P235R15XL tires. Thanks for the comments. I'm confident that the ratio change will dramatically improve the driveability of this truck, which in all other respects, I really enjoy.
Old 02-27-2002, 11:57 AM
tch777 tch777 is offline
tch777 is starting off with a positive reputation.
TCH
I've got 3.55s in my 96 F-150 5 speed and it is doggy with the 31 x 10.5 x 15 tires on it. If you are going to stay with your current tire size the 3.73 ratio will work well with a good performance economy balance. If you will tow alot or haul heavy loads and maybe do bigger tires someday 4.11's would be a great choice. I have a 91 Suburban 1/2 ton 350 CID that I am running 33 x 12.50 x 15 tires on, when I got it there were 3.73s in it and was terrible on the highway and in town, now I am running 4.56s and I increased mileage from 12 to 16 mpg and the performance step up was awesome.
Hope this info helps you out...
Old 02-27-2002, 12:43 PM
71mustang 71mustang is offline
71mustang is starting off with a positive reputation.
leveling kit Airframes4life 1999 to 2016 Super Duty 10 03-29-2014 11:57 AM
change gear ratio from 3.55 to 3.73 ncl Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 9 04-29-2013 07:20 PM
which gear ratio FordYoungGun35 1987 - 1996 F150 & Larger F-Series Trucks 15 03-07-2013 03:59 PM
how to I know the rear gear ratio on my 1992 ford f150 4x4? 1992FordF150Custom 1987 - 1996 F150 & Larger F-Series Trucks 2 09-22-2011 01:11 PM
96 Bronco Seats moocow7777 1978 - 1996 Big Bronco 2 07-15-2003 10:00 AM
Tags
1987, 1995, 373, 4x4, 50, 95, change, choice, f150, ford, gear, gearing, gears, ratio, stock, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
