Someone who knows numbers
Yep, the lack of a COLOR code and the fact that there are 6 digits in the DSO (indicating it was a special order truck - not an off the lot purchase) would indicate it had at least a special order color. A DSO code comprised of only two digits would indicate a non-special ordered truck.
BarnieTrk
BarnieTrk
D = 352 2V
P = Twin Cities MN Assembly Plant.
648491 = 1965, assembled February 1965.
115" Wheelbase.
Color = Blank.*
F100 2WD .. 5,000 lbs. GVWR
481: 4 = Light Beige Crush Vinyl & Light Beige Wicker Pattern Vinyl / 81 = 81A Standard Cab.
A = Ford type 3.03 3 Speed Manual all Syncromesh Transmission.
08 = Ford 9" Rear Axle / 3.50-1 / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM
443257:
44 = Twin Cities MN Ford District Sales Office, where the original selling dealer ordered the truck from.
3257 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
*When there is no COLOR code stamped on the Warranty Plate, truck painted a non standard color per the original purchasers order, making it a Domestic Special Order.
Thanks Bill!
It was interesting to me that in the last 50 years the truck hasn't gone very far, from twin Cities MN, to Sioux City, IA, and now to northeast NE.
And I found it interesting that the 352 c.i. motor only made 172 hp.
I did know a little by looking at the VIN, such as that it came from Minnesota, but I was hoping to get the full treatment from NumberDummy!
Thanks Bill!
It was interesting to me that in the last 50 years the truck hasn't gone very far, from Twin Cities MN, to Sioux City, IA, and now to northeast NE.
And I found it interesting that the 352 c.i. motor only made 172 net hp.
Thanks Bill!
So in 1966, under what conditions were those two HP numbers determined?
I'm guessing that GROSS HP was measured at the flywheel (no transmission or anything else behind it) AND without any V-belted accessories up front...?
Whereas NET HP would have been measured..... where? ...at the driveshaft behind the transmission and WITH the standard V-belted accessories (what else besides the alternator)?
BarnieTrk
BarnieTrk
DontKnowJackS
18
09-27-2018 01:10 PM
salvaged66
49
01-28-2017 04:33 PM
