Electric fan cooling
Flexilite fans offer a universal fitting electric fan that will fit a superduty. Model # 290, thier website is www.flexilite.com click on automotive link . If you get one post how the install went, and if you saw a performance difference.
Goodluck.
Goodluck.
I shop around when I go to by things for my truck. There is an dual 15" electric fan combo by Flex-a-Lite that is lets you adjust the temperature from 160 to 240 degrees.
I know of two individuals that have installed this set up on their trucks, one a diesel and the other a V10. Both love it.
You can also write to Flex-a-Lite and have a custom applicaiton made up. www.flex-a-lite.com
I need some auxiliary cooling on my 1971 F250 (360 cid). The cooling system can't keep up when the AC is turned on and I'm driving in stop and go traffic. Especially when driving in deep south texas.
I would like to keep my stock fan. So I looked into pusher fans but I don't have any room in the grille area.
However, I have enough room for a flex-a-lite trimline 116 fan (as a puller fan) inside the stock shroud between the radiator and the stock fan.
Flex-a-lite says that this would work well. However, I would like some commentary from the folks out there.
Regards,
David
Regards,
David
dyoungen
11-15-2012 03:43 PM
idahoturbo94
06-06-2010 02:26 PM
NICODEMUS
06-05-2005 11:29 PM
Smason
08-28-2002 03:42 PM
