2011 tranny - Ford Truck Enthusiasts Forums
2011 tranny
Old 09-07-2015, 05:54 PM
2011Ford 2011Ford is offline
2011Ford is starting off with a positive reputation.
2011 tranny
bought my std cab 11 5.0 used w 15k…..since the day of purchase its always had a slight shudder on the highway in 6th……. few years later ….very far from stock I've noticed the output shaft on tranny has play in it….also weeps fluid….i now have 4.10's 35's……. it rides pretty good on the highway considering but still vibrates like a bad u joint…..i think the problem is the sloppy output on the tranny? any advice,possible fix….warranty is up and i know the dealer will look at my truck and blame a million and 1 things as to why its sloppy…..truck shifts good no other issues other than slop/vibration and weeping fluid……i do have a sct 5star tuner with higher shift points and pressure. 48k currently
Old 09-13-2015, 01:49 PM
nobody has had a trans tail shaft issue with their truck?
mine has a **** ton of slop…but its strange sometimes it will tighten up and vibes will go away but most days its loose and vibes are annoying, plus Its doing damage I'm sure…
maybe some one can give me relative driveshaft angle starting from trans to rear end (on 2 piece shaft) everything i know about lining up 2 piece shafts does not match fords angles????
Trans Fluid? KDAVID1 6.0L Power Stroke Diesel 9 09-02-2016 06:57 PM
1997 mountaineer slips when cold sawmaned Explorer, Sport Trac, Mountaineer & Aviator 6 07-26-2016 03:08 PM
overfull transfer case adam10 1999 to 2016 Super Duty 8 03-15-2014 08:06 PM
5.0 LITRE TRANSMISSION DIPSTICK GONE? Big-Red-Lariat 2009 - 2014 F150 23 06-27-2011 07:10 AM
Power Steering Issues after repair.... Unimog005 1967 - 1972 F-100 & Larger F-Series Trucks 10 08-01-2008 07:33 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
