6 Volt Starter Rebuild, 52 F-3
#31
#32
Yeah, $250 is a bit much when I can buy one instead. I know I didn't have everything I needed for a "proper rebuild". I thought I'd be OK with the armature and coils as the starter worked. Just slow.
No I did not paint it at all..........yet. Someone got into my paint for their own project and I had to get my truck out of the driveway before I had an H.O.A issue.
I was going to use black epoxy paint on the outside. Undecided as to the inside. It was bare metal when I took it apart.
#34
Not only am I a tight a$$, I like to repair instead of replace if I can. You know what you have when you're done and I enjoy the challenge.
I get on line and research the repair if I have never done it before. Find the best price I can on QUALITY parts and go for it.
I knew the price of worse case scenario was still less than buying a starter. Especially if you figure in the price of shipping of the new one AND the core.
I got lucky and did not have to buy an armature and coils.
#35
For $40, what could they be doing? That's not even an hour's labor, and a set of brushes is about $10. I don't see how they could be replacing the bushings, growling the armature, cutting the commutator, etc. Sounds like a clean and paint job, to be honest.
#36
#37
Another reason beside the generator brushes not being copper, is that the generator runs continuously, and at higher RPM than the engine. The commutator on a starter armature doesn't wear much at all on a rig that starts easily. - Bob
#38
This was 10 years ago and he is a reputable older man. The starter still works great today..... remember rural PA.
#40
Generator brushes are mostly carbon? Starter brushes have a bit of copper. As you mentioned a starter armature doesn't run too much, and the current is very high.
"The mica is not usually cut from between the bars of the armature on a starter motor. This is because the brushes used on a starter have a high copper to carbon content and would otherwise wear out the commutator very fast."
#41
Jesser02EX
88
11-05-2021 08:38 PM
