Rotors and pads for a 2001 F350
Hey guys, I need to replace my trucks front brakes soon and I'm wondering if i should just stay with Motorcraft or is there something else you recommend? I will also add that Six months out of the year the truck will be towing our 10,000lb fifth wheel. Thanks,
Kevin
Kevin
I believe I bought the Power Stop K1890-36 kit from Summit. Cross drilled and slotted rotors, with ceramic pads, for the front only.
They are a noticeable difference over stock rotors and L-cheap-O pads.
However, at very random times, I do get the warped rotor feel. It is not all the time, it is not consistent, but it does happen to me every now and then. I have not checked to see if the rotors themselves are warped, or if it is even in the rear rotors, so it isn't that bad. Maybe its just me. I don't drive that hard or tow that much, and I run the manual trans, so there is a big load taken off my brakes.
I wish I had better records, but I'm thinking 3 years and 20k miles and they are still not that worn down and make no noise. I would recommend this package.
Casey429
05-15-2012 01:54 PM
