1996 Ford F150 4.9l Wont Start
I have a 1996 ford f150 4.9l i6 5 speed. I drove it to work and shut it off and it shut down perfectly, no chugging no sounds or anything like that. After work, when I tried to start the truck it just cranked over. I had the vehicle towed home and since have replaced the ICM, Coil, Pickup assembly (inside distributor), crank case position censor, cap, rotor, sparkplug wires and plugs, and the fuel filter. I took off the timing cover and alined the timing gears with #1 piston at TDC and put the distributor in pointing at #1 on the cap. The truck has 52 psi of fuel pressure at the rail. The truck has spark and it has fuel and still will not start. I also looked at the inertia switch and it was perfectly normal, was not popped up. My fuel pumps also work. I need help figuring this out, thanks in advance.
I'm having the same problem with my 1988 f150 302.. Fuel pressure is at 40psi which the spec is 35-45. And has spark.. I've replaced the ICM, MAP, and EEC relay.. The only way it will start is with starter fluid then it will idle fine but it's very rich. I've seen this similar problem several times but never a fix.. Someone has got to know something. The check engine light is on and scanner won't pull any codes.
But if you disconnected the battery then you also blew away any codes that were there as well.
Bear999
13
10-03-2015 09:23 AM
lgb2004
17
10-02-2015 05:26 PM
1979fordf-150
11-19-2010 01:01 PM
