Y Block noise
Well I removed the valve covers to find one broken push rod. Not sure what is going on though. Looks like oiling was ok.
The engine was rebuilt about 4 years ago ,it now has about 4k on engine. I have not adjusted the valves since then. The next time I work on it I will fish out the broken push rod, hoping for some answers.
Terry
Terry
Same issue
Terry
Terry
PS. There's a few great threads about valve adjustment in the Y block performance section should you need a reference
In my case I had 10 gallons of gas I removed from a car that was 5 years old. Being cheep I put it in the truck to use. I learned my lesson on that , anyway it caused one valve to stick and bent a push rod. I will run through all of them when its back together. What caused your pushrods to bend?
59Terry
One thing you'll want to do when you're ready is adjust the valve lash. Here's a link to the easiest and yet most accurate and consistent across all cylinders method I have found. It's also very quick and takes about 15 minutes once ya get the hang of it.
One of the keys to making a Y block run sweet is accurate valve adjustment. I like to run a bit of Marvel's in the fuel, especially if not used as a daily.
http://www.potomacbird.com/pctc/Publ...-valvelash.pdf
Old51f3
05-07-2019 05:38 AM
19 f250 88
08-10-2013 11:41 PM
