Vent/cowling channel cleaning
I picked up a '64 F-250 that's been sitting under a juniper tree for over a year and the channel in front of the windshield is full of debiri. Is there any way to easily clean it out? I've been holding a vacuum over it while i work a flat piece of metal in the slot. It's slow going.
john
john
Another related problem through the cowling openings is the heater box will accumulate enough leaves and pine needles or whatnot to start on fire.
What happens is, the blower motor has a wirewound resistor that gets red hot during operation and this has resulted in several trucks totaled by fire. Be sure to check this too.
I don't know if the your '64 has the cover plate like my '65 and '66 trucks. Pop the hood and look for a cover plate dead center below the cowl drain channel. If it is take out the screw(s) and remove the cover. I've made flexible attachments that I can suck out the debris. Don't forget to clean out the driver side and passenger side drain channels. You can access them through the vent doors.
Good luck- Tom
Good luck- Tom
How does a guy even get to it - do you have to remove the entire heater box out from under the dash?
BarnieTrk
It depends, of course. The OP, on account of an Arizona truck may not even HAVE a heater. I think they were an option in those days. So.
My 64 has the "fresh air" heater option, and taking off the box cover was able to get to most of it with a vacuum cleaner and a piece of wire, etc. It's a PITA.
Good luck- Tom
Good luck- Tom
There's also an article in ddavidv's website, 'how to clean' drain points. In disassembling the 65 I found several drain points clogged and consequently developed serious rust issues. May want to browse the site, there's also interesting 'how to' article on the front disc upgrade.
Ford
1TonBasecamp
32
05-03-2020 01:30 PM
