Rear Axle U-bolt torque spec????
Old 09-03-2015, 08:10 PM
2civicrr's Avatar
2civicrr
2civicrr is offline
I did some searching but was only able to find the one post that listed the torque spec for the u-bolts/nuts for the rear axle spacers (250/350 4wd).
Can someone confirm if the info below is correct? Thanks
Tighten u-bolt nuts in 4 stages using a cross pattern.
Stage 1 - 48 lb-ft (65 Nm)
Stage 2 - 96 lb-ft (130 Nm)
Stage 3 - 148 lb-ft (200 Nm)
Stage 4 - 195 lb-ft (265 Nm)
Old 09-03-2015, 08:25 PM
dirtymutt's Avatar
dirtymutt
dirtymutt is offline
There seems to be a few varying specs out there. I set mine to 160ft lbs as I found one thing that stated 195 and another that said 150ft lbs. Sorry I know this doesn't clarify your question though.
Old 09-04-2015, 05:42 AM
Just Strokin's Avatar
Just Strokin
Just Strokin is offline
Per Ford 2015 Service DVD
With the suspension at curb height, tighten the U-bolt nuts evenly in a cross-type pattern in 4 stages.
Stage 1: Tighten to 65 Nm (48 lb-ft).
Stage 2: Tighten to 130 Nm (96 lb-ft).
Stage 3: Tighten to 200 Nm (148 lb-ft).
Stage 4: Tighten to 265 Nm (195 lb-ft).
Old 09-04-2015, 07:46 AM
Big-Foot's Avatar
Big-Foot
Big-Foot is offline
.....and.......
Unless it is specified in the torque spec ::
Use NO OIL on the threads to do your torquing... Any lubricant will cause the torque to be wildly inaccurate. I've seen a lot of stripped threads by people lubricating them and then torquing to spec.
Old 09-04-2015, 09:47 AM
2civicrr's Avatar
2civicrr
2civicrr is offline
Thanks guys. Appreciate the help.
Eric Kropp
11-01-2014 10:12 AM
Eric Kropp
10-31-2014 02:45 PM
homesteader
11-18-2010 03:06 PM
joe chevy
1999 to 2016 Super Duty
11-23-2009 07:33 PM
brad3384
2004 - 2008 F150
06-20-2007 07:32 PM
Quick Reply: Rear Axle U-bolt torque spec????
