6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Fan stator mod to ease belt replacement
Old 09-03-2015, 03:04 PM
dlibson's Avatar
dlibson
dlibson is offline
I asked a while back if anyone had done it, no one had. So I did mine, and then another one. I got pics on the second one though.
I basically cut just the top out to keep and use. Only for the fan wiring so I didn't have to lengthen it at all.
Complete stator:
Cut out part:
Garbage:
On truck:
Doing the belts underneath is now a breeze, can be done in 10 minutes without moving anything out of the way.
Also, this can be done with out removal of the stator. First one I did I cut with a sawzall on both sides of the top, then on bottom in the middle. Pulled both halves right out.
Old 09-03-2015, 04:08 PM
Herb Brooks's Avatar
Herb Brooks
Herb Brooks is offline
What does the stator do?
Old 09-04-2015, 06:23 AM
dlibson's Avatar
dlibson
dlibson is offline
It's designed to rotate air around to quiet the flow of air. It's also said it helps move the air around to cool. However, I've seen no ill effects or higher temps at all.
Old 09-04-2015, 07:58 AM
Tom's Avatar
Tom
Tom is offline
<p>Interesting idea David. &nbsp;Added to the tech folder!</p>
Old 09-27-2017, 01:05 PM
Alexsha's Avatar
Alexsha
Alexsha is offline
4wd Low
I'm interested in this mod, but there pictures don't work anymore. Can they be reposted?
Tonto Kowalski
13
03-21-2019 01:58 AM
Scotty's 52 F3
76
09-21-2017 10:12 AM
ihcc104
08-21-2016 08:58 AM
Ibuildmyown
15
02-06-2015 09:05 PM
chetspencer
08-03-2012 11:11 PM
Quick Reply: Fan stator mod to ease belt replacement
