Blown turbos... who has had one
Hey fellas,
I partake on the 7.3 boards but wanted to run over here and ask you about your 6.7s and the longevity on the turbos. We have had a ton of guys loosing turbos on their 14 and newer rigs. Most tow heavy and bought the truck purposely for work. I was curious if this was what you guys were seeing at all if you use the truck for hauling often rather than DD???
When I say going prematurely they are going ever 30-40k miles. They have all been covered under warranty, but there are a few that are on their second and third turbo. I have a half dozen ranchers trucks that lost them before 50k. Predominantly they are 450/550s
I thought I would come over here and ask and see what you guys have seen with your rigs.
Not trying to poke or irritate at all. I was just curious.
Thank you.
Thank you.
Good to know. I was curious. These trucks are not deleted, just left alone. I was surprised to see so many going and 30-45k seems to be the magic number for their first turbo , but there are a few oddballs that can almost cut it in half. But they are strictly for hauling.
Just curious if you are to pay out of pocket, what does a dealership charge? for anyone that may have gone down that route?
Anybody gone with a bigger charger?
Received 1,447 Likes
on
The bulk of the turbo failures came from the single turbine turbo used in the CC 450/550 trucks. The turbo's in the '11-'14 are prone to failures if tuners are added, but even stock trucks have had failures. I'm not aware of any improvements to the turbo's from '11-'14 years, although the failures have seam to have dropped off.
The '15 turbo's is where the design change was made and these should be as bullet proof as they get.
I won't work on the newer trucks, but I have a lot of friends/farmers/coworkers that are going through turbos like crazy and I just wanted to ask. I am not used to seeing it, let alone on the newer trucks.
Is it an oiling issue or overspool issue? Why not run a little bit bigger charger?
