wiring question
wiring question
I am working on a 2014 Lariat, just installed air lift air bags on the rear suspension, installed an on-board controller in the cab. I located the gauge and switch on the side of the center console but cannot figure out where to tap into a wire to illuminate my gauge. Anyone know what color wire under the dash by the drivers side might work? Thanks in advance for your help.
It's better to use a switched power lead. If the OP does use the same switched power lead to illuminate the gauges I guess it wouldn't be too big of an issue if they were illuminated all of the time.
nlemerise
33
02-16-2019 01:25 PM
