2000 Excursion V10 Camshaft Position Sensor
Been troubleshooting an annoying Chirp sound in my engine compartment. Eliminated anything connected to the serp belt, and it changes with RPM's, and needs to be under some load (can't duplicate in driveway, ever). It is a kind of squeak, chirp, metal sounding squeal that really sounds like some sort of bearing going bad. Read that sometimes a failing spark plug can make such a sound before it gets ejected from the motor, so I just changed all of the plugs and cleaned everything up nicely. Made no difference in this sound.
Next thing I've heard can make some noise is Cam Position Sensor. I can't find any info on where it is located on this V10. World wide web has been no help. My wife and I both get the strong sensation that this noise is coming from the engine compartment, passenger side. I'd venture to say it's somewhere near the firewall. The other day I was revving it up a bit with my face to the motor and I heard one brief squeak that sounded like it's from that area as well. I may have a couple of small exhaust leaks as well, but it really doesn't sound like that.
Can anybody point me to the CPS sensor on this truck so I can try to get a stethoscope on it? Getting ready for a two hour drive hauling my camper and kids and dogs for the weekend, and I'm still a little worried about what this sound may lead to.
Thanks!
Thanks!
Thanks!
Thanks!
Sounds like you are describing an exhaust leak to me. As RPMs (and pressure) builds a small linear leak can get a squeal going that sounds just like a bad bearing. Check around where the exhaust manifold mates to the head and at the downpipes, I think you might find your leak/squeal there.
After looking at the images of the replacement part , it doesn't look mechanical like some of the other vehicles sensors I've seen. I guess I agree this is unlikely to be my issue. Thanks.
I've got to be honest my friend. My solution was to trade it in on a used Nissan Armada. The company I traded it to was pretty sure it was internal engine, but if you have any broken exhaust manifold studs, I really would start there. Seems like the sound would build with exhaust pressure so I feel it is air escaping around the manifold. Impossible to make it happen with the truck standing still. Grrrrr. Good luck neighbor.
sunuvabug
19
07-12-2018 02:54 PM
