Quick question 54 F500
I tried to find your measurement using reference material, but neither the Salesman's Handbook nor Body Builder's Layout Book gives this for the front axle. One of the guys will need to measure his truck. Make sure you factor tire size between your truck and the one that gets measured. Stu
My 50 F5 is 69", with 8R19.5 tires on Alcoa rims. I know that the 53/56 front axle is 4.61" wider, then you need to take into account tire size. My best guess, pending somebody with a 53/56 posting their measurements is about 75".
Most trailers would have no problem with that width, but more importantly is the length. What wheel base is your truck, 1954 F 500 came in 130" and 154" WB. The 154" was the most common WB and if that is what you have you will need at a bare minimum an 18" trailer. The other consideration is weight. What is your trailer rated for? If the truck is just cab/chassis, with original wheels and tires probably close to 5,000#, however, if it has an old grain / dump body with 2 speed rear and PTO you could be looking at 7-10K#, way too heavy for a car hauler with 7K# axle rating.
As an example, here is my 158"WB F5 (empty weight 5,000#) on my 18' trailer, being pulled by a V10 Super Duty. Note that the front end extends over the A frame of the trailer (puts bumper very close to tow vehicle) which did break a tow vehicle tail light with bumper on a very tight turn. Also, see how the 12' bed extends past the end of the trailer.
Really?? Hope you don't plan on using a cheap 5,000# towbar, your trip is less than 20 miles, with no hills or grades and your tow vehicle is at least a 1 ton with brakes in like new condition.
Nice ride! Sheet metal looks clean too. I can't see even a spot of rust-throughs in this picture. And that's quite the funky custom bed there. I rather like it!
Oddly I got a bunch of parts of a '53 nearly identical to this truck. Same Meadow Green too. And it had electric wipes. My '56 has vacuum wipers. Must have been an optional purchase.
Hope she fires up!
LeoJr
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
02-27-2014 07:51 AM
joshofalltrades
06-14-2012 03:03 PM
deanzawistowski
23
03-27-2008 10:05 PM
ollie21b
13
10-18-2004 11:20 AM
