Need a meeting of the minds on this one!! HELP!!!
I have those isolated. The HPOP lines aren't even connected to the heads. They are raised higher than the HPOP reservoir so in this case they aren't causing the drain.
Thanks for the ideas. Keep them coming!!
That's not what I wanted to hear. So in order to figure out if that's what it is I have to pull the engine?
It could be the lower hpop gasket: #8-009 HPOP Engine Mounting Gasket 96-03 - High Pressure Oil Pump - 1999-2003 Ford 7.3L
I would get in touch with Bob or Clay and see what they think.
Is it possible that it is the IPR?
Well if that has been verified I think the next thing you could do here is with the cover off pour some oil in yourself and try to see where it is going. Meaning is it draining right away or half full or what? Maybe even do a video for the rest of us while you do it so we can better help you on this one. As tearing this thing up would be a real bear bro.
Let it drain completely down, then add just a few drops of oil and watch. Add a few more if necessary until it starts to drain. Then watch the little bit of oil slowly drain until it stops. The puddle of oil will shrink around the drain location until it's gone. Just like water in a bathtub.
I forgot about the HPOP gasket. That would allow the entire reservoir to drain back into the pan. Might be worth a shot.
Originally Posted by Pikachu
I sure wouldn't. If the front cover is cracked, the oil pan needs to be dropped to replace it. If the oil pan needs to be dropped, the engine needs to come out.
#28
#29
Clues:
- The top of the picture is the slush box for the HPOP, and it is full of oil to the highest rim - you can see oil there. No leak here.
- The LPOP feed is on the bottom of the photo, and you can see oil drained way down the feed hole.
- There are no leaks anywhere on the truck.
#30
Clues:
