What else should I replace?
5.4L with 160k. Going in the shop next week for a leaky manifold intake gasket. While its in there i am going to replace upper and lower intake manifold, injectors, plugs, rad hoses, waterpump, and fan clutch. Belt, coil packs and thermostat are all new. Anything else u guys would change or replace?
I would replace all vacume lines and pcv valve, those things are cheap and are common things people dont ever check or change out. If you have some extra cash get an aftermaket throttle body with a new air intake system if you dont already have one. You could also get a programmer. If i think of other ways to spend your money ill let you know.
Cool. I'll stop bugging your threads, I always just remember a '92 5.8 I had, previous to any of the trucks in my sig and I replaced parts after parts to get that motor running right, which it never did because it had low compression. Whole different animal I know but I blew a ton of money on that thing. So now I'm the compression ****, a spark plug can barely be pulled with me around without me trying to hook up a tester. I drive my buds crazy too!
I do wish you the best of luck with your truck.
2005 Ford F20 Crew Cab 5.4l 3 valve
Mark53207
06-01-2004 04:48 AM
Kemicalburns
1978 - 1996 Big Bronco
01-03-2003 10:47 PM
