New fuel pump, now NO CRANK
I swapped out my fuel pump this weekend due to my fuel level sensor float coming off the arm. Got a new tank pressure sensor because I broke the old one trying to swap it.
Reinstalled everything.
It started up just fine. Although I did turn the key to the ON position for a few seconds and listened for the fuel pump- couldn't hear anything (but I can't remember hearing the fuel pump energize with the old pump either). Let it idle for a few minutes. Drove it out of the garage. Parked it on the street overnight. Drove it to work (15 minutes) this morning.
Tried to go to lunch. Turned the key and it wouldn't crank. Scangauge reads 11.6 or so volts. Checked all sorts of fuses and they all are good. Pulled a few relays- nothing melted.
Ideas?
Ideas?
Then check the easy (cheap) stuff first.
Are the battery connections CLEAN and tight?
What about where the battery cable terminals connect to the battery cables?
Follow the positive battery cable down from the battery to the starter, especially where it passes near to the passenger side exhaust manifold to be sure it is not burned.
Not sure what year vehicle and engine you are referring to, but that 11.6 volts is kinda low. Is that being read with the key off or with the key in the crank position?
Try jumping the battery. If cranks, you need battery. If not could be one of three things.
1. The ground strap from engine to frame rail has corroded or come loose.
2. The starter or starter solenoid has failed. (Solenoid is on the starter)
3. Bad cable from battery to ground (negative black cable) or to starter (red positive cable)
Battery came back good. Checked the ignition switch under the steering column with a multimeter and it checked out good.
Followed the diagnostic procedure in my Haynes manual for the "in vehicle check" for the starter. I can get the truck to start by jumping the 2 terminals on the starter relay on the firewall with a screw driver. I'll replace that and it should solve my problem.
Did you bother to check to see if the starter relay is even getting its signal to turn on? If it isn't and you replace the relay, you'll be back here in a day or so bitchin' that it still won't crank.
If you do not troubleshoot it properly, you can expect that luck will be the primary factor in getting it right.
Not necessarily.
