94 gauge problem
09-01-2015, 01:01 PM
on
94 gauge problem
i have a 94 f150 4x4 5.0 and my oil pressure and temp gauges don't work right. i have replaced the sending units from advance and they still are not working right. should i buy from ford?
09-01-2015, 01:05 PM
on
or should i just put mechanical s under the dash?
09-02-2015, 08:03 AM
on
09-02-2015, 09:28 AM
No one has an idea of your problem statement "my oil pressure and temp gauges don't work right" meaning. No advice to give based on the broad interpretation of "don't work right".
Please clarify your issue(s).
09-03-2015, 10:30 PM
on
ok my temp gauge reads almost to the hot but the ecm gauge sys it 180 along with my hand held gauge. my oil pressure gauge moves all over the place and i changed both the sensors and they are bwd brand i am just wondering if i should just go get ones from ford
09-04-2015, 05:09 PM
<p>you do not have "gauges" in your truck, you have glorified idiot lights.</p><p>as long as you have around 7 psi or more oil pressure the oil gauge will read good.</p><p>temp will either read green or in the red.</p><p>to know what is really going on put a set of mechanical gauges under the dash.</p>
09-04-2015, 05:30 PM
Were the sensors bad? Did you ground out the wire and check to see if the gauge pegged out? If the gauge is bad go get replacement from the junkyard or replace them with aftermarket. Don't have my '94 here to look at it...are those two gauges on the same panel?
09-04-2015, 10:32 PM
on
the sensors go bad like once a year i am most likely going to put the mechanical gauges in it
09-04-2015, 11:18 PM
Gauging the problem...
If you have two gauges failing at the same time chances are the voltage regulator on the instrument cluster is the culprit. It is also possible a loose connection or crack on the printed circuit may also be the cause.
bert cook
11-15-2015 10:36 PM
DeadBody
16
12-30-2012 09:32 PM
MrRogers
11-16-2007 05:07 PM
JKK
03-05-2006 07:25 PM
BigRedSD
1999 to 2016 Super Duty
17
01-13-2004 04:04 PM
