2005 E350 Flashing Headlights
I had that problem too
There is a headlight module that controls the DRL's. It keeps them on dim when key is on, then goes to regular bright when you pull the headlight switch on.
The replacement module is under $60 at Rockauto. I didn't want to spend that money when my headlights were flashing, so I just unplugged it. Now I have regular headlight operation with no DRL.
The module is under the plastic cover that is atop the radiator top.
