Aerostar Ford Aerostar
Ign Sw or A/C
Old 09-01-2015, 12:55 AM
JTHill24's Avatar
JTHill24
JTHill24 is offline
Question Ign Sw or A/C
Ok here is the Problem.........
89 Aerostar.
Start it but have to back the Ign-Switch back to get the A/C fan to come on.
Also to make the Turn signals work. Seems like some Play.
Does/Has anyone had this problem & what Needs to be Replace or can be fixed/Tightened?
Is it in the column or a switch or Spring?????????????
HELP!
Old 09-01-2015, 08:25 AM
DFord's Avatar
DFord
DFord is offline
I never did understand the connection but I had problems like that when the brushes wore out in my blower motor and I had to replace it. After that, all was well again.
Old 09-01-2015, 02:28 PM
Jose A.'s Avatar
Jose A.
Jose A. is offline
sounds like a worn ignition switch. It is obvious because the fan or the turn signals will not come on without the ignition switch being in the RUN or in the ACCESSORY position.
you can get ignition switch replacements on eBay. Being a 1989, looks like time to replace it.
Old 09-01-2015, 10:16 PM
JTHill24's Avatar
JTHill24
JTHill24 is offline
OK this is what Fixed all my Problems.............
Just wanted to let you know.
Duralast/Ignition Switch LS514 at AutoZone.com - 1 reviews
Jhow88
11-11-2015 10:54 AM
Thumper19
07-26-2012 09:14 PM
jayrus544
2004 - 2008 F150
05-06-2010 08:11 PM
Dylansdad
09-20-2007 01:59 PM
rickj000
08-07-2004 05:50 PM
Quick Reply: Ign Sw or A/C
