What Truck do I need?
Ok, here goes again.
Just courious on what truck everyone thinks I should get to pull a Travel Trailer with a dry weight of 7300lbs? It is a 35ft (bumper to ball). Let's just say I put an additional 1500lbs of cargo (which I don't think I ever will), that would bring the weight up to 8800lbs.
What Truck would pull it with no problems IF I decide to pull it to the mountains etc??
Thanks in advance
Tony
Thanks in advance
Tony
The 250 and 350, if ordered in the same configuration and with the same options, will be 100% identical physically. The 250 is just de-rated on paper to fill a different market segment. That said, with the trailer in question, either a 150 or 250 would be a good fit.
Tony, I have a F150, 5.4 and pull a small 21' TT and I'm looking at a super duty. The F150 pulls it ok if you like to let the engine rev. Pulling at a high altitude with a head wind Requires the engine to run at high RPMs. Just returned from a 6,600 mile trip to Yellowstone and beyond. Both exhaust manifolds cracked. They were white from the high temps. It's not just the weight your pulling. It's also the flat surface your dragging through the wind. Yes a 150 will do it. But.
Trailer Towing Vehicle Choice
just my opinion.
Ken
My take on the question at hand......if you are going to do a little towing and just once in a while in the mountains.....F150
If you are going to do a lot of towing, mountains, hills, plains, or whereever.......F250 or F350! If nothing else, just for the 6R140 transmission!!!
This tranny will win hands down over the 6R80 transmission in the half ton!!
One thing to remember, especially across the great plains, there may not be big hills, but there will be some pretty good cross winds at times!!!
The engines in the half tons have pretty good power, but long days of hot weather will take its toll on the lighter duty transmission.
F150dana44
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
12-16-2004 06:42 AM
johnman
12-16-2004 12:04 AM
