Bed/Box swap options
Old 08-30-2015, 02:45 PM
BigB6958's Avatar
BigB6958
BigB6958 is offline
I have pretty much everything sorted to begin the process of rebuilding my 66, except the bed. Everything is good except the floor of the bed, which is rusted through pretty much all across the front area where it connects to the front wall. And of course that's also the part no one makes a repro of. So I want to know what the options are around a complete bed swap. Do I have to use another 66 donor - VERY hard to find a bed in good condition that is not attached to an entire truck in good condition and is $$$ because of that - or can I adapt another year (maybe the 77 I am buying to use as a donor for the rest of the stuff I needed??)
I realize there will be some wheelbase differences and some mounting differences possibly, but just wonder what I can do since what I have is not very useable. Thought about diamond plate, or completely new flat steel or aluminum cut to fit, but I really don't want to cut the entire floor out and hire someone to do all the welding for me if at all possible.
I am open to any and all ideas...thanks for helping!!
Brad
Old 08-30-2015, 04:06 PM
EricJ's Avatar
EricJ
EricJ is offline
What bed, and how long? if you like stepsides you can pretty much use any year up to present as long as it's the same length. IE; 6 0r 8 foot.
Old 08-30-2015, 04:18 PM
BigB6958's Avatar
BigB6958
BigB6958 is offline
Sorry about omitting those facts....Styleside LB. Don't like the look of stepsides personally.
Old 08-30-2015, 07:21 PM
john jamieson's Avatar
john jamieson
john jamieson is offline
One thing people over look are trailers made from truck beds. Just saw one in the tucson craigslist area sell for $450 and it looked real solid. It was listed under trailers.
Old 08-30-2015, 07:30 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Same Styleside beds: 1964/66 F100/250 2WD / 1966 F100 4WD
1967/72's have a raised scallop line (called a Bumpside); 1973/79's have a concave scallop line (called a Dentside). Neither will match the cab lines of your 1966.
Upper pic: 1967/72 / Lower pic: 1973/79.
Old 08-31-2015, 08:06 AM
69supercj's Avatar
69supercj
69supercj is offline
Where are you located?
Old 08-31-2015, 09:02 AM
BigB6958's Avatar
BigB6958
BigB6958 is offline
Calgary AB Canada
Old 09-01-2015, 09:32 PM
hoss73ford's Avatar
hoss73ford
hoss73ford is offline
Pickup beds that have been made into trailers are a good source of finding one as it seems they were removed before suffering further abuse. I did that myself rather than scrap it. The outer shell was fine but like yours the floor has rust issues up front so I got a sheet of 16 gauge steel and covered the whole thing (wouldn't do that to one attached to a truck tho)
Meridian_Mike
03-19-2019 06:39 AM
AmongHidden
05-18-2012 07:07 AM
664x4drvr
11-12-2011 07:43 PM
janddp
08-04-2011 10:53 PM
Sycostang67
01-30-2003 09:58 AM
Quick Reply: Bed/Box swap options
