Yet another 4r100 problem.
Installed rebuilt transmission 1 month ago. Have noticed reverse has started to go away. Feels like it is slipping or tires are losing traction with a lot of vibration in the steering wheel.(tires are not slipping that's just the way it feels) Does it worse when trans is up to temp. I suspect feed bolts but want opinions.(Mark K.) All forward gears seem fine with no issues. I have never been under the pan deep enough to access the feed bolts. Any suggestions,instructions on doing that procedure.
on
Doesn't sound like Feed bolts if Forward gears are not affected. When I had the Forward Clutch Feed bolt back out, I had slippage in Forward, but Reverse worked fine.
It could be loose Valve body/Reinforcing plate bolts, leakingVB gasket, or bad apply piston seal. Take it back to the rebuilder and let them check it out.
Fishin76
04-06-2015 08:39 AM
onelionhunter
10-07-2014 11:37 AM
78250crewcab4x4
01-28-2007 06:47 PM
