Which is better
Which is better
My question is,I have a 95 f150 302 with stock heads and stock rear end with 3.55 gears.I tow a 4500lb trailer and on level ground no problem.When I tow up hills and higher elevation ( 3000 to 8000 feet ) I struggle a bit.I changed the cam to a .480lift 260 duration,installed shorty headers and 3" cat back exhaust this help a lot but I need more.What would get me more towing power.Fords aluminum racing heads with 194 intake or switching to 3.73 or 3.90 rear end gears.
if it were mine, I'd be doing the heads. you stand to gain way more with the heads...and you could bump compression into the 10's and run 89/93 or 91 if its available in your area. also I'd be eagerly waiting for the 302 to seize so I could replace it with a 5.8 or a stroker winsor.
itll be near upper 2000's for rpm with 4.10s at 70. id rather have the power.
I would take the 2k RPMS at 70 MPH.
Gears are your best friend. ...assuming you can set them up. The OP already has a cam so I vote for a more reasonable gear for a towing rig....especially a 5L model.
The other consideration is whether the truck has factory converters. If so, ditch them for an aftermarket high-flow.
If it were me, I would swap to at least a 4.10 ratio (3.90 if your a cheap bastid like me and don't want to buy a new carrier) Although I'm not sure that 3.90's would make that much of a difference, or be worth the time of setting up the rear end... I also rarely drive the highway, and spend most of my time between 20-50 mph (depending on how big of hurry I am, and how bad the gravel road is that I'm traveling on), so as with everything, YMMV..
Plus, the gears would be a lot cheaper than a new set of aluminum heads..
I installed a 3" cat back exhaust with a magnaflow muffler.The cat is high flow.Also installed headers.The cam I installed is a Comp cam with .480 lift both intake and exhaust and and 206/216 duration.After installing all this I did notice a big improvement but I need more,that is why I was thinking of new heads to take advantage of the mods I already made.
