2012 SD Rear suspension blocks
Hey all. I have a quick question, but thinking of changing out my stock OEM rear axle blocks for the 2012 F350 SD 4x4 SRW type.
Does it matter what the wheelbase is?? Model being a CC, SC, etc?
Or...are all 2012 F350 SRW rear axle blocks the same??
Thanks,
biz
Thanks,
biz
If the block numbers have not changed there are two different versions based on wheel base length. See thread below for which part number's you need.
https://www.ford-trucks.com/forums/6...ar-blocks.html
What year is your truck? It appears from a quick search that at some point all trucks started coming with the 4" blocks because of the sag. What year is your truck? How does it feel towing like that with the nose high?
https://www.ford-trucks.com/forums/1...-rear-sag.html
Thanks everyone for the replies!! Really appreciate it.
I'm going to perform the Tsb 13-3-8. That is the Tsb that addresses rear sag with light loads. However, I cannot find the actual Tsb.
Can someone point me to the Tsb?? I'd like a copy before I walk into the FORD dealer to purchase the parts.
Thanks!!
biz
Thanks!!
biz
I'm about to do the same thing to my F250.
HERE in the TSB.
I also looked at this 4" block hit from 4WheelParts - Pro-Comp 4" Kit. Not sure if we need the EXP62244 or EXP62242
Haven't price out the Genuine Ford Parts vs Pro-Comp yet though.
Keep us (me) posted on what you decide. I sadly wont be attacking this project for a couple weeks or more.
HERE in the TSB.
