Recalibrate speedo after gear swap.
No need to recalibrate for a gear swap, only for the tires. This is because the tone ring bolted to the carrier is what is used to generate the vss signal (instead of the old setups that used the trans output shaft). So the only correction needed is for tire size when going from axle rpm to vehicle speed.
If the speed sensor is on the top of the rear end you shouldn't need to change anything. I went from 3.08 to 4.10 and speedo stayed correct. Mine was a 95 so maybe that's the difference. You would have to change the setting if you went to different tire size though. Thought I had read something at the time that said it would only allow you to change it like 8 times or so.
Nightrain
08-04-2006 08:06 PM
customfoam
12-19-2004 05:15 PM
tyson1992
05-17-2004 05:04 PM
Johns331
03-05-2000 06:48 PM
