temp gauge not working
on
These dash gauges read low anyway but there are only a few things that could be causing your issue. As mentioned if the thermostat is stuck open the motor will take a long time to heat up, a simple test for that is just switched on the heater.. if you get lots of heat the thermostat is probably OK.
The sender could also be bad or the connection to it corroded. It works by grounding the gauge, so test that by removing the wire and grounding it on the engine.. the gauge should peg. The sender location depends upon your engine, it's not the device on the thermostat housing it's a little single wire thing about the size of a dime either in front of the #5 injector in the lower intake on the V8s or down on the side of the block under the upper intake for the I6.
LARIAT 85
20
10-13-2010 06:02 PM
sfc11b
04-16-2005 10:19 PM
will
09-21-2004 04:00 PM
Teresa66
05-31-2003 01:06 PM
