Pulling right front axle?
Old 08-28-2015, 05:57 PM
Nader's Avatar
Nader
Nader is offline
I'm about to remove the right front axle to replace seals. I've torn it down to the hub carrier (with the hub bearing unit removed) and I can't pull the axle out. It feels like it's hung up on something soft, like another seal somewhere inside the axle tube. What am I doing wrong?
Old 08-28-2015, 06:40 PM
JOHN2001's Avatar
JOHN2001
JOHN2001 is offline
Have you pulled the diff cover? I don't recall if there is a C clip on the inside of the axle or not. It's been awhile
Old 08-28-2015, 10:24 PM
Baatzy's Avatar
Baatzy
Baatzy is offline
If you have everything off down to and including the hub bearing unit then all you are missing is a good pull. I generally stick a pry bar in the u joint area and use that for leverage. There is no c clip holding the axle in the center.
Baatzy
Old 08-30-2015, 01:39 AM
pirate4x4_camo's Avatar
pirate4x4_camo
pirate4x4_camo is offline
^ yup, it's just the inner seal and splines in the spider gear giving it some resistance. A pry bar gets the job done.
mcali2
02-24-2017 10:45 PM
Billyclub
15
07-10-2016 07:33 PM
bigtuna128
1999 to 2016 Super Duty
04-09-2009 12:59 PM
fingarr
09-27-2007 09:25 PM
tuke
05-07-2006 08:37 PM
Quick Reply: Pulling right front axle?
