Two 1990 F-150 Fixes
Received 3,090 Likes
on
depends on what is broken in the ignition switch components.
if it is just the key cylinder, that is about a 2 minute job. if it is the ignition actuator that is broke, that is roughly a 1.5 to 2 hour job. if it is a bad ignition switch, that is about 1/2 hour to swap.
a pinion seal replacement is not that bad. remove drive shaft, remove pinion yoke, remove seal, and drive new seal in. anywhere from 1/2 hour to 3 hours, depending on whether it wants to fight you or not.
Kapusta
04-15-2020 04:32 PM
mino54
02-28-2005 06:01 PM
mino54
01-27-2005 01:46 PM
