The "Mule" Build
#571
Pretty much. You will probably want 2 torque wrenches if possible. One for the smaller bolts and one for the big. A feeler gauge set would probably be good to check ring gaps but if your machinist matched your new rings to the cylinders then it's probably net nessecary. Plastigauge to check the bottom end. And a ring compressor. Are you doing the heads yourself or did you get the machine shop to deal with them? Also are you doing your injector cups while your in there as well?
#572
#574
#576
Lol. My machinest has time next week to put the short block together thank god, he knows how to put these things together and at a price that will make your jaw fall down in disbelieve in a good way $150 updates as soon as I can.
My starter went out yesterday good thing it has lifetime warranty.
#579
pgg00, his engine guy backed out, so it looks like he's back to doing it himself.
Adam, for what it might be worth, here is kind of a basic 7.3L assembly guide:
Ford Power Stroke Engine Assembly Guide - Step by Step
#581
I was toying early with the cheapo scanner left by the previous mechanic (I have AE for Chrysler,Ford, Chevy) and the dam thing worked on my Mule came with a lot of not to good codes concerning oil pressure.
Here they are:
P1280 ICP sensor circuit low (I unplugged it some time ago might be a fluke)
P1282 excessive ICPressure
P0344 CPS A circuit intermittent (I unplugged it with out unplugging the battery and has a brand new IH CPS)
P1212 ICP not at expected level
P1278 Cyl 8. High to low side open
So it all point to either bad O rings on injectors or bad IPR rings.
Symptoms I'm having surging idle, lost power and what appears to be a cylinder misfire.
What do you guys think?
Forgot to add a pic of the scanner
Here they are:
