door won't open from the inside or outside?
1996 f250 xlt. The door locks move up and down when the button is pushed,so I don't think the lock is sticking. every now and then if you hold your mouth right,the door will open. The door latches seem to be working fine and aren't broken. What could be causing it and how hard is it to pull the door panel off and maybe see what is broke?
From the inside, you could have a stretched cable or torn sheet metal where the handle mounts.
Door panel comes right off after pulling out some screws. Slide it forward off the inside handle. If you have armstrong windows then of course you'll need to pull the crank off too, one bolt in the center.
Doubt it is a stretched cable since there aren't any. The handles, lock actuator and lock button are connected to the latch using rods retained by plastic clips. Sometimes the rods aren't adjusted correctly in the clip or it slips inside the clip. It could still be the latch hanging up. Try spraying it with white lithium grease.
^^^^^ Vicious cycle - cable stretches, reduced "response" from handle. Rather than diagnosing, operator pulls handle harder. Stretches cable more, puts more stress on handle mounting point on door structure. Operator pulls handle harder still. Rinse, repeat. Until mounting point fails. So once you get it apart, if the handle mounting is damaged, it can be repaired, but at FIRST sign of inside handle ops issues, open it up and adjust/repair before it reaches this point.
At this point, getting the interior panel off is possible, but a tight-quarter operation with the door closed. Look for screws along the bottom of the panel, "hiding" in the carpet/fabric of the panel. Disconnect and remove the window/lock switch panel first, of course.
"Hail Mary" option - in case it's just a latch adjustment issue, have an assistant hold the button on the exterior handle and pull outward, while you throw your shoulder linebacker-style against the door from the inside.
ok,haven't had the chance to work on the door or mess with the truck since I posted this. Went out just now to tinker with it. Now the door opens fine from the inside but still doesn't from the outside. I never did anything to it to make the inside handle start working. Why would the inside handle just start working for no reason?
ok,now it gets even better. Both handles work like they should....and I didn't fix a thing. Would it be possible for the lock not to be unlocking all the way on the driver's side? The lock on the door seems to be a little (maybe only 1/4") higher then it was when the door wouldn't open. I had tried to grab it with a pair of needle nose pliers the last time I messed with it,but there wasn't enough sticking up to grab.
solution
The latch is old and stuck. Push the rod down. this will reset the latch. then open the door with the either inner or outer handle. After you get the door open, remove the panel and watch a youtube video on how to remove the latch. Clean the latch and oil it. If that doesn't work, buy a new latch, they are on amazon or LMC truck for $80.
