Add Front Camera
Adding options to a vehicle that wasn't equipped is rarely plug and play these days. They have completely different wiring harness and sometimes different computers. The cost to buy all the parts factory ends up pretty stupid as well.
If you want to tackle it, youd have to go to a parts department, identify all the unique parts to the front camera, check to see if any computers and other components use different part numbers, and then order them too. You'll need a VIN of the body/options you want and your own vin to cross reference. You'll also need a very patient parts counter person who isn't busy and feels like wasting his time. I don't mean that to be rude, but it probably won't go anywhere. This is just the process I would do to make a change close to factory spec.
If I were contemplating this, I would try to get my hands on a manual to see what, if any, wiring you would have to add. I'm speculating that the wiring harness won't support what you want to do, and anything you put in the cab would have to be add-on.
It would pretty much be a MacGiver kind of job, but if you're into that sort of thing, it might be a fun project (I've MacGiver'ed a few things in my time, and it can be a kick).
This is plug-and-play and will give you additional connectors for more cameras:
https://www.coastaletech.com/mytouchair.htm
Then you'd have to buy the camera and wire it up.
I can't personally vouch for it, but I saw that someone in one of the forums is using it.
Tsoptich
06-26-2010 06:01 PM
Chris60F100
07-13-2004 01:25 AM
