Towing....the reason I bought the truck
SCT with a tow or trans-only tune is a good addition for any truck. No two run alike, so try a couple of programs to see if you like how it shifts better. A couple of trans-only programs or something like the 8k tow from Gearhead.
I'd put in an EGT gauge, and get the FICM flashed with Atlas 40 from PHP, then use a trans-only tune.
7,000 lbs is nothing for the 6.0. I've pulled loads like that and at times forgot it was back there unless I looked in the mirror.
Per the others, put the truck is tow/haul and the truck will do the rest. All you have to do is tell it if you want to accelerate or stop.
I tow about the same weight your talking about, no problem for these trucks, if you find yourself on a grade and it seems like its lugging, step on the gas and knock it down a gear, raise the rpms it will push more air through the motor and lower your egt, the tow haul mode usually does this but not always, with this weight, ( lite)
Well wouldn't doing a trans upgrade disturb the trans? I mean I've never services a trans over 100k without prior knowledge of service history. I don't really feel like messing it up. So I'll just leave it alone and make sure she has plenty of fluid. I'm pretty confident in the 6.0 and not worried to use it as a truck. That engine needs weight behind it every now and then.
don't add any additives/cleaners.
#30
